redistributing eigrp basic question
Jun 20th, 2007
Hi Lads,
I need a little advise in redis eigrp in rip . attached is a visio detailing what I need to do , its been a while since i dont any of this , basically there are two router running eigrp between them and anther router connected to one of them speaking rip , I need one of the eigrp learned route to be know in rip . thanks alot , also do I need to do the reverse also ??
the serial interface are shut down this is ethernet both side of the network. thanks
attached is the config for B in the diagram.
interface FastEthernet0/0
description ##### LAN #####
ip address 10.68.0.249 255.255.224.0
ip access-group 101 in
no ip redirects
speed 100
full-duplex
nterface Serial0/0
description ##### FRAME RELAY TO#####
bandwidth 256
no ip address
encapsulation frame-relay
no ip mroute-cache
no fair-queue
frame-relay traffic-shaping
frame-relay lmi-type ansi
nterface Serial0/0.1 point-to-point
description ##### FRAME DLCI TO #####
bandwidth 256
ip address 10.54.254.18 255.255.255.252
ip summary-address eigrp 1 10.68.0.0 255.255.0.0 5
no ip mroute-cache
frame-relay interface-dlci 17 IETF
class wexford256kcompress
frame-relay payload-compression FRF9 stac caim 0
nterface FastEthernet0/1
description *** *** 10Mbps To ***
ip address 172.17.100.2 255.255.255.252
duplex auto
speed auto
nterface Serial0/1
no ip address
shutdown
outer eigrp 1
redistribute static
network 10.0.0.0
network 200.2.20.0
network 200.2.26.0
distribute-list 1 out Serial0/0.1
no auto-summary
router rip
version 2
redistribute static metric 1 route-map RIP
network 172.17.0.0
no auto-summary
p classless
p route 0.0.0.0 0.0.0.0 172.17.100.1
p route 10.68.0.0 255.255.0.0 FastEthernet0/0 tag 5
p route 192.168.8.0 255.255.255.0 10.54.254.17
o ip http server
ap-class frame-relay *****kcompress
no frame-relay adaptive-shaping
frame-relay cir 256000
frame-relay bc 2560
frame-relay mincir 256000
ap-class frame-relay 256k
frame-relay bc 2560
ccess-list 101 permit tcp host 10.68.0.33 host 192.168.8.11 eq 8080
ccess-list 101 permit tcp host 10.68.0.14 host 192.168.8.11 eq 8080
ccess-list 101 permit ip any 10.47.0.0 0.0.255.255
ccess-list 101 deny tcp 10.68.0.0 0.0.255.255 any eq 8080
ccess-list 101 permit ip any any
oute-map RIP permit 10
match tag 5
nmp-server engineID local 0000000902000001966F3099
nmp-server community ********
nmp-server community *********
nmp-server enable traps tty
anner exec ^CC
Overall Rating: 4 (1 ratings)
Edison Ortiz Wed, 06/20/2007 - 08:41
If you want to advertise the 10.68.62.0 network over to RIP, do the following on router B:
route-map EIGRP-TO-RIP permit 10
match interface f0/0
route-map RIP-TO-EIGRP permit 10
match interface f0/1
router rip
version 2
redistribute connected route-map EIGRP-TO-RIP metric 3
router eigrp 1
redistribute connected route-map RIP-TO-EIGRP metric 1 1 1 1 1
kcornally Wed, 06/20/2007 - 09:33
thanks EdisonOrtiz,
could you give me a brief explanation as to what
the above is actually doing if its not too much hassle .
Edison Ortiz Wed, 06/20/2007 - 10:54
route-map EIGRP-TO-RIP permit 10 +++++ (create a route-map with the name)
match interface f0/0 +++++++ (match the ip address of interface fastethernet 0/0)
route-map RIP-TO-EIGRP permit 10 +++++ (same as above)
router rip
version 2
(redistribute connected routes that match the route-map specified above with a metric of 3)
router eigrp 1
redistribute connected route-map RIP-TO-EIGRP metric 1 1 1 1 1 (same as above)
kcornally Wed, 06/20/2007 - 13:11
thank EdisonOrtiz,
I really appreciate you taking the time to explain that just one final question , the match
interface command is it matching routes learned on that interface or is it redistributing the network range of the interface .
Thanks again.
Edison Ortiz Wed, 06/20/2007 - 15:52
The match interface is just a faster way to match a particular connected network.
Let's take your FA0/0 for instance:
no ip redirects
speed 100
full-duplex
You want to redistribute the 10.68.0.249 into a routing protocol using a route-map.
You can
a)
route-map CONNECTED permit 10
b)
ip access-list standard CONNECTED
permit 10.68.0.0 0.0.31.255
match ip address CONNECTED
___________
both route-maps perform the same function but using the access-list requires a bit more typing :)
kcornally Wed, 06/20/2007 - 09:53
thanks EdisonOrtiz,
royalblues Wed, 06/20/2007 - 13:26
Friend,
when you use a match interface command under the route map, it Matches routes that have their next hop out one of the interfaces specified
HTH, rate if it does
Narayan
sundar.palaniappan Wed, 06/20/2007 - 13:33
Narayan,
I am afraid that's not correct. When you match and interface it only covers the IP subnet of that interface. In this case the only subnet that would be redistributed into RIP/EIGRP is the one that's configured on the interface.
Sundar
smothuku Wed, 06/20/2007 - 20:44
Hi Sundar ,
I think Narayan is correct in this regard..when you speciy match interface , it distribute any routes that have their next hop out one of the interfaces specified.
I've checked it in cisco and following is the info..
match interface (IP)
To distribute any routes that have their next hop out one of the interfaces specified, use the match interface command in route-map configuration mode. To remove the match interface entry, use the no form of this command.
match interface interface-type interface-number [... interface-type interface-number]
no match interface interface-type interface-number [... interface-type interface-number]
Usage Guidelines
An ellipsis (...) in the command syntax indicates that your command input can include multiple values for the interface-type interface-number arguments.
Use the route-map global configuration command, and the match and set route-map configuration commands, to define the conditions for redistributing routes from one routing protocol into another. Each route-map command has a list of match and set commands associated with it. The match commands specify the match criteria?the conditions under which redistribution is allowed for the current route-map command. The set commands specify the set actions?the particular redistribution actions to perform if the criteria enforced by the match commands are met. The no route-map command deletes the route map.
The match route-map configuration command has multiple formats. The match commands may be given in any order, and all match commands must "pass" to cause the route to be redistributed according to the set actions given with the set commands. The no forms of the match commands remove the specified match criteria.
A route map can have several parts. Any route that does not match at least one match clause relating to a route-map command will be ignored; that is, the route will not be advertised for outbound route maps and will not be accepted for inbound route maps. If you want to modify only some data, you must configure a second route map section with an explicit match specified.
Examples
In the following example, routes that have their next hop out Ethernet interface 0 will be distributed:
route-map name
match interface ethernet 0
Note :Pl correct me if it is wrong...
Satish
kcornally Thu, 06/21/2007 - 03:40
thanks very much for all your help , it seems fine now.
thanks..
Kevin
Edison Ortiz Thu, 06/21/2007 - 05:09
Satish,
You are correct but let me explain why my example won't involve routes being sourced from F0/0.
In the redistribute statement, I specified to only redistribute connected routes that match the route-map and I've labbed up for illustration:
Here is an ABR running ODR and OSPF
Its ODR RIB is as follow:
R1#sh ip route odr
51.0.0.0/32 is subnetted, 1 subnets
o 51.51.51.51 [160/1] via 172.16.15.2, 00:00:10, Serial0/1
[160/1] via 172.16.15.6, 00:00:10, Serial1/0
69.0.0.0/24 is subnetted, 1 subnets
o 69.69.69.0 [160/1] via 172.16.15.2, 00:00:10, Serial0/1
o 222.22.2.0/24 [160/1] via 172.16.15.2, 00:00:10, Serial0/1
__________________
So I have ODR enabled on S0/1 and S1/0 with the above routes. Let's say there is a spoke router running OSPF that needs reachability to the 172.16.15.2 address.
I do the following:
R1(config)#router os 1
R1(config-router)# redistribute connected route-map ODR subnets
and the route-map is:
route-map ODR permit 10
match interface Serial0/1
Now, if I go the spoke OSPF router
R4#sh ip route os
172.16.0.0/30 is subnetted, 1 subnets
O E2 172.16.15.0 [110/20] via 183.1.254.1, 00:01:23, Serial0/0
______________________________________
If I were to redistribute routes matching the source interface, then I would use the routing protocol that interface is running under, in this case ODR
R1(config-router)#redistribute odr route-map ODR subnets
R1(config-router)#
and if I go to the OSPF router:
R4#sh ip route os
O E2 51.51.51.51 [110/20] via 183.1.254.1, 00:00:22, Serial0/0
O E2 69.69.69.0 [110/20] via 183.1.254.1, 00:00:22, Serial0/0
O E2 222.22.2.0/24 [110/20] via 183.1.254.1, 00:00:22, Serial0/0
