06-20-2007 08:45 AM - edited 03-14-2019 10:11 PM
Have a customer who is experiencing call disconnects when they place an outside call on hold for about 30 sec. CallManager is 5.1 and gateway is using MGCP.
Anyone have any ideas about this?
Solved! Go to Solution.
06-20-2007 08:48 AM
Try the following command on your gateway.
no mgcp timer receive-rtcp
Hope this helps. If so, please rate the post.
Brandon
06-20-2007 08:48 AM
Brandon
06-20-2007 09:01 AM
That worked! What does that command do?
Thanks so much for your help.
Chris
06-20-2007 09:26 AM
Chris,
This command turns off the timer for RTP/RTCP packets. Without this command, the call will be disconnected after a period of receiving no RTP/RTCP packets. While the call is on hold, it is receiving these packets from the MOH server. Take a look at the following link.
Hope this helps.
Brandon
06-20-2007 10:35 AM
Thank you so much for the reply!
Chris
09-25-2007 03:54 PM
I have similar problem with a h323 gateways. calls are disconnected in different periods of time, between 2 min to 28 min.
CCM Version: 4.2(3)sr2b
h323 Gateway IOS Version: c2800nm-advipservicesk9-mz.124-17.bin
Any suggestions appreciated.
Carlos
