MARS "Blank Error Message"
Jun 20th, 2007
  • Silver, 250 points or more
I was wondering if anyone had seen the words "Blank Error Message" while working from the CLI on MARS 4.2.6
We first saw it while upgrading and later saw the same message while setting the Timezone.
They don't appear to mean anything as we were able to do the upgrade and set the timezone. Is this a cosmetic bug?
Thanks!
Anonymous (not verified) Tue, 06/26/2007 - 10:13
CSCsc91430?A blank error message is displayed when you update your client software
Description: During a service pack or point patch installation, a system prompt tells you to uninstall Security Manager Client. Unless you click the OK button, an error message that contains no text is displayed.
pmccubbin Thu, 06/28/2007 - 05:49
Thanks for the reply.
The Bug you posted was for Cisco Security Manager. I noticed the words "Blank Error Message" while working from the CLI on an upgrade of MARS. I just ignored it and everything to date is running fine.
