assistance setting a PIX to PIX tunnel
Answered Question
Jun 20th, 2007
We are replacing a PIX at a branch office. A tunnel was establised with old PIX at branch office. A tunnel cannot beestablished with new PIX and central office PIX. Branch office has connection to the internet with new PIX. A tunnel can not be established between PIX at central officeand branch office. Could you provide assistance. The following is the config at the branch office PIX.
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
domain-name falcon.local
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
<--- More --->
nat (inside) 0
access-list 102 permit ip 10.6.6.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list 100 permit ip 10.6.6.0 255.255.255.0 192.168.1.0 255.255.255.0
pager lines 24
logging on
logging console debugging
logging monitor debugging
mtu outside 1500
mtu inside 1500
ip address outside xxx.103.120.130 255.255.255.248
ip address inside 10.6.6.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 xxx.103.120.131-xxx.103.120.134
global (outside) 1 interface
nat (inside) 0 access-list 100
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
conduit permit icmp any any
route outside 0.0.0.0 0.0.0.0 xxx.103.120.129 1
timeout xlate 0:05:00
<--- Mor
timeout uauth 0:05:00 absolutexxx.55.241.12:/i/bin/1.3.200703
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set toyota esp-des esp-md5-hmac
crypto map bmw 1 ipsec-isakmp
crypto map bmw 1 match address 102
crypto map bmw 1 set peer xxx.213.196.10
crypto map bmw 1 set transform-set toyota
crypto map bmw 2 ipsec-isakmp
<--- More
crypto map bmw 2 set transform-set toyota5):/baynote/tags2/b
telnet 0.0.0.0 0.0.0.
! IncompleteBuilt dynami
crypto map bmw interface outside3 to outside
ssh 0.0.0.0 0.0.0.0
crypto map mbmw 1 ipsec-isakmpen=1
isakmp enable outside
isakmp key ******** address xxx.213.196.10 netmask 255.255.255.255
isakmp key ******** address xxx.100.116.90 netmask 255.255.255.255
isakmp identity address
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption des
isakmp policy 1 hash md5
isakmp policy 1 group 1
isakmp policy 1 lifetime 86400
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
dhcpd address 10.6.6.2-10.6.6.31 inside
dhcpd dns 192.168.1.5 67.100.88.26
dhcpd lease 3600
<--- Mor
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Correct Answer by JORGE RODRIGUEZ about 10 years 1 month ago
Could you tell us on the replaced pix whether it has proper 3DES/AES License, without this feature enable you will not be able to perform site-to-site vpn.
issue at the command line " show version "
and post the results.
Jorge
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Wed, 06/20/2007 - 18:45
  • Green, 3000 points or more
Jorge
