Accessing DMZ from Inside -- No NAT
Jun 20th, 2007
I'm trying to configure my ASA 5510 so that I can access servers in the DMZ (security-level 50) from machines on my inside network (security-level 100) and vice versa.
The machines in the DMZ are on the subnet and the inside machines are on I don't need NAT since there's no addressing conflict.
I tried two approaches:
access-list inside_dmz extended permit ip
nat (inside) 0 access-list inside_dmz
static (inside,dmz) netmask 0 0
The second method works; the first doesn't. What am I missing here? Why doesn't the first method work?
acomiskey Wed, 06/20/2007 - 11:34
That should work fine either way. When you did "nat (inside) 0 etc." were you going from inside to dmz? Any logs on the ASA when it failed?
spottedowl Wed, 06/20/2007 - 12:39
It doesn't work in either direction. Nothing notable in the ASA logs either.
