Unity Failover..
Jun 20th, 2007
I was wondering if anyone knew whether or not Unity failover is based on Exchange clustering?
Overall Rating: 4 (1 ratings)
ranpierce Wed, 06/20/2007 - 11:50
The failover Unity server is configured exactly the same as the primary and its partner server is the same as the primary's.
The secondary is just a standyby Unity server that takes over when the primary is inactive.
I hope this helps some.
jmachiggins Wed, 06/20/2007 - 11:53
Thanks. I read that as a no. Am I right? So, it the few seconds for a failover mentioned in the docs accurate?
thisisshanky Wed, 06/20/2007 - 12:05
Yes thats correct. You can test failover testing using the Unity tools depot tool called failover monitor. You can manually do a failover from primary to secondary. I have hardly seen any failed calls with my past clients while doing a failover testing.
