ASA 5505 as dynamic address VPN client
Patrick Laidlaw Fri, 06/22/2007 - 00:41
You can search for easy vpn. The PIX 501 use to support being an easy vpn peer.
What you can also do is just setup the asa with dhcp and then run the vpn wizard.
If your looking for actual ASA OS help you can post your config and I can help.
Patrick
