Multiple CPE's on LAN
Jun 20th, 2007
I have a wireless network bridge to wired lan and will need multiple wireless CPE devices off that LAN...I'm curious how to handle multiple 192.168.1.1 subnets throught the rest of the network.....
umedryk Wed, 06/27/2007 - 05:44
  • Bronze, 100 points or more
Use the command show controllers lre cpe mfg to verify that the CPE Model Number string is correctly set for this CPE. Use the command hw-module slot lre upgrade remote to ensure that the CPE has the latest firmware. Use the interface configuration command shutdown followed by no shutdown to force the switch to re-fetch the CPE firmware version and checksum. As a last resort, power cycle the CPE.
