Issue in accessing servers through remote access vpn 5510
I have configured remote access vpn in my ASA 5510 on an interface which has security level "10".I am able to successfully connect to the vpn from the client but unable to access the server on INSIDE lan.Can someone let me know if it is possible to terminate vpn on Interfaces other than OUTSIDE interface.
Thansk in advance
acomiskey Wed, 06/20/2007 - 16:09
Technically, a security level 10 interface could be your outside interface, so this should not make a difference. We'd have to take a look at the config to help you out here. Usually the symptoms you describe are caused by nat-t. Post a clean config and we'll take a look.
