Disabeling SSH Version 1 on a cisco switch
Jun 20th, 2007
I am currently running a Cisco 3560 48 TS Switch with 12.2(25)SEE3. I am trying to disable version 1 of the protocol, but unable to. I have used no ip ssh version 1 and I still see SSHv1/2 Servers running with the show ssh command. Is there a command or set of commands to shut down ssh version 1 ?
a show ip version says version 1.99.
How do I get it to select 2.0 so it does not use version 1?
sundar.palaniappan Wed, 06/20/2007 - 14:27
Configuring 'ip ssh version 2' should disable support for version 1.
Here's an excerpt from the link below.
Note SSH Version 1 is a protocol that has never been defined in a standard. If you do not want your router to fall back to the undefined protocol (Version 1), you should use the ip ssh version command and specify Version 2.
http://cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00802045dc.html
Sundar
royalblues Wed, 06/20/2007 - 23:20
In addition to sundar's post, when you enable SSH version 2, it always shows as 1.99 in the IOS the reason for which is not known :-)
Narayan
