Warning message
ASA 5540 Remote Access Issue
Jun 20th, 2007
Having an issue with our ASA5540 and remote access (hardware VPN client 3002). I am able to successfully create the tunnel and access the internet, but I am not able to ping the remote access hardware client from an inside host or vice versa. We are not using split tunneling. Any help would be appreciated.
shomar Wed, 06/20/2007 - 23:44
Try to check weather Nat-T is enabled on the ASA or not.
look for the command 'isakmp nat-traversal' in the configuration, add it there if its not enabled.
Shadi`
