06-20-2007 03:45 PM - edited 03-10-2019 03:13 PM
Hi List, we've adquired a new ACS v4.1 Solution Engine, before we used UCP, with ACS 3.2 Windows based. Can I enable UCP over ACS Solution Engine? is it possible? or maybe I have to use a diferent server...
Thanks...!
Omar
06-20-2007 04:09 PM
Omar,
UCP can't be installed on Appliance, you need to have another server. AS ACS SE is build on
a hardend Windows OS, and is not accessible as a normal Windows OS server.
If we want to use UCP, we need to install UCP on a seprate Windows server, which has IIS
server running.
Jagdeep
06-21-2007 05:32 AM
I agree with Jagdeep
Also would recomend checking the following link for UCP:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/acs41/ucp41/ucp.htm
06-21-2007 07:41 PM
Thank you for your response, but at this moment a Windows Server is impossible for me (reason: money) other possibilities? Apache/Linux?
06-22-2007 02:17 AM
I have made it to run on Apache server, though only tested with HTTP, not HTTPS. But I know this for sure that it works with Apache.
Instructions will be same as for IIS, just make sure that you give enough privileges on "securecgi-bin" folder so that it can execute the scripts.
Have done this long way back. But yes this works.
Its worth a shot.
Prem
07-06-2007 09:53 PM
Hi ,
I have cisco ACS 1113 ,i have made windows vista desktop with IIS 7 ,i have configured iis ,given required privilege to securecgi-bin but still,'secure-bin' is not executing ,...i will be thankful if any one help me...thxxx
07-07-2007 08:59 AM
IIS 7 is not tested with UCP, so it may/may not run properly. And it has not been tested with vista desktop.
To make it run, please ensure that you have following requirements fulfilled ,
To install UCP, you must have a web server that runs either:
?Microsoft IIS 5.0 (included with Windows 2000)
?Microsoft IIS 6.0 (included with Windows Server 2003)
Prem
07-08-2007 04:34 AM
Thax ...
06-22-2007 02:20 AM
FYI,
So if you face any issues with operation of UCP on Apache, TAC may not be able to help.
But we are here, so lets try our best :)
Cheers,
Prem
