aghaznavi Tue, 06/26/2007 - 14:38
I think you have to create an oem.ini file containing only the part that configures silent mode. In this file, you turn Silent Mode on, identify the pathname and folder to contain the software, and reboot the system, all without user interaction. A sample oem.ini file for implementing silent mode follows:
[Default]
SilentMode = 1
InstallPath = C:\Program Files\Engineering\
DefGroup = CNA users
Reboot = 1
aborole Tue, 06/26/2007 - 15:28
The silent install is not officially tested/supported for CNA but you could try invoking the executable from command line using "-silent" which is generally supported on installshield installers
Gordon Fecyk Mon, 09/19/2016 - 06:54
Is this seriously a problem after nine years?
Back in 2012 I converted the CNA 5.8 kit into a Windows Installer package so I could do unattended installations. I also had to add a post-install script to change some folder permissions to accommodate User Account Control prompts and local non-admin user accounts on Windows. Did the same thing in 2014 with the 5.8.9 kit.
It looks like I'll have to do this again with the 6.3 kit. I'd distribute the resulting kit but I think Cisco would take exception to that.
For anyone with a Windows Installer builder of their own, it's pretty easy to make a kit from the installation source. The installer just needs to add a shortcut to prelaunch.exe in .\utilities\prelaunch, and add a post-install script that grants Modify permissions to the installation folder for BUILTIN\Users.
Or Cisco could spend $300 or less for someone's MSI builder and roll their own.
