Help with Caller ID
Jun 20th, 2007
I was wondering if anyone could help me with the problem below.
We are running Cisco CallManager 4.2 with a 2821 Integrated Services Router as the Voice Gateway to the external PSTN (ISDN PRI).
Whenever someone rings out of the office, the number is seen externally as coming from a single person's phone, no matter who it is making the outside call.
Not sure to look at the gateway or someother area of CallManager?
In the gateway config I have set outbound "Caller ID DN" to be 02890568XX but the number always comes from
Any help would be greatly appreciated.
Overall Rating: 4 (2 ratings)
gogasca Thu, 06/21/2007 - 00:10
  • Green, 3000 points or more
Ok since you are using ISDN PRI.
Telnet into the vGW and do a debug isdn q931 then term mon.
You will see Calling Party number IE. in SETUP message
that is the caller ID you are sending to the PSTN. Paste this output, is this the same number PSTN user is seeing?
Othwerwise you may check with your Telco. or play with num type and num settings in CCM or maybe the GW if H323 or SIP is overwritting this value.
BTW are you using H323, SIP or MGCP?
bvial1989 Thu, 06/21/2007 - 15:39
005998: *Jun 22 10:37:55.248 PCTime: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0299
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838A
Exclusive, Channel 10
Calling Party Number i = 0x0081, '0289056800'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '1300361070'
005999: *Jun 22 10:37:55.348 PCTime: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8299
006000: *Jun 22 10:37:57.748 PCTime: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8 callref = 0x8299
Progress Ind i = 0x8288 - In-band info or appropriate now available
006001: *Jun 22 10:37:58.096 PCTime: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8299
006002: *Jun 22 10:38:01.748 PCTime: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x8299
006003: *Jun 22 10:38:01.752 PCTime: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0299
gogasca Thu, 06/21/2007 - 15:56
That is what GW is sending to Telco
Which type of GW is being used?
SIP,H323 or MGCP?
If no translation in GW, CCM is the culprit, please provide detailed CCM trace.
bvial1989 Thu, 06/21/2007 - 16:00
We are using MGCP.
You can see the Calling Party Number above is 0289056800 even though teh call was made from a phone with a different extension to that. This is the number the external PSTN users are seeing.
So, I can now safely assume it is not the Telco as this is the number we are sending them.
As I said, on the gateway we have the "Caller ID DN" Set to 02890568XX and in CCM itself, also in the Router Patterns we have not set any values under the "Calling Party Transformations" section.
Thanks for your help.
