Resilient TFTP
Jun 20th, 2007
i am going to do a tftp resilient config at one of our customer, i could not find any good document, only the SRND one.
i have cluster with two CCM 7825 in CCM 4.2(3)(LAN with one location only).
1) I need a good step by step document if any
2) Did any one have done this before and is there any draw back!!!, best practice!!!
Good day
Overall Rating: 1.5 (2 ratings)
eug-c Tue, 06/26/2007 - 21:05
Like what Wong said, this resilient configuration is for IOS.
What do you mean by TFTP resilient config?
Are you talking about having a resilient IPT setup with 2 CallManagers?
If so, you are right, the SRND shows the deployment models for a resilient IPT setup.
Eugene
twissam Wed, 06/27/2007 - 09:46
Hi it is for CCM indeed, i have done the test today and it worked well. Of course the Extension mobility got crasy as expected.
One thing you need to make sure that the TFTPath folder should be syncronised if it is not (copy and past) i donno if this is a supported way or if this folder does sync itself but it is working and this what matters.
Good day
