Private VLAN Across Multiple Switches
Jun 20th, 2007
Hi Sir,
I have one unit Catalyst 6513. I configured a PVLAN with VLAN 30 as primary VLAN and VLAN 31 as secondary isolated VLAN.
Ports connected to hosts are configured as follows:
interface GigabitEthernet3/1
switchport
switchport private-vlan host-association 30 31
switchport mode private-vlan host
Hosts can't talk to one another but they can communicate with the SVI (interface Vlan30).
There's a requirement to extend some hosts to another non-Cisco switch which will trunk to this Cat6513. How should I configure the trunk port on the Cat6513 to preserve the same security model as when the hosts are directly connected to the switch?
E.g.
interface GigabitEthernet12/9
switchport
switchport trunk allowed vlan 30
switchport mode trunk
Allowed VLAN should be 30 or 31? Do I have to configure the command "switchport private-vlan host-association 30 31" on this trunk port?
On another note, do you know the difference between the following two commands:
(1) switchport private-vlan host-association 30 31
(2) switchport private-vlan association host 30 31
Please advise.
Thank you.
B.Rgds,
Lim TS
smothuku Wed, 06/20/2007 - 21:36
Hi Lim,
I know that the command "switchport private-vlan host-association" is used To define a PVLAN association for an isolated or community port.
Usage Guidelines
There is no run-time effect on the port unless it is in PVLAN-host mode. If the port is in PVLAN-host mode but neither of the VLANs exist, the command is allowed but the port is made inactive.
The secondary VLAN may be an isolated or community VLAN.
Examples
This example shows how to configure a port with a primary VLAN (VLAN 18) and secondary VLAN (VLAN 20):
Router(config-if)# switchport private-vlan host-association 18 20
Router(config-if)#
This example shows how to remove the PVLAN association from the port:
Router(config-if)# no switchport private-vlan host-association
Router(config-if)#
Have you configured "switchport private-vlan association host 30 31" on 6513 switch.
did it accepted ?
Satish
limtohsoon Thu, 06/21/2007 - 01:45
Hi Satish,
When I typed the command "sw private-vlan association host 30 31" on the Cat6513, it turns out to be "switchport private-vlan host-association 30 31" in the running-config. So I presume these two commands are equivalent.
I'm more concerned about PVLAN across multiple switches via 802.1Q trunk. Found some technotes below:
http://www.cisco.com/en/US/partner/tech/tk389/tk689/technologies_configuration_example09186a008017acad.shtml#multiple_switch
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst4500/12.2/31sga/configuration/guide/pvlans.html#wp1167271
Cisco recommends the use of standard trunk ports (regular trunks)if both switches that undergo trunking support PVLANs. I doubt if the non-Cisco switch that's gonna trunk to my Cat6513 supports PVLAN.
In that case, I may need to configure PVLAN trunk. However, it's not supported on the Catalyst 6513 [IOS version 12.2(18)SXF8 - IP SERVICES]
Cat6513(config-if)#sw mod private-vlan ?
host Set the mode to private-vlan host
promiscuous Set the mode to private-vlan promiscuous
I'm out of idea. Please help.
Thank you.
B.Rgds,
Lim TS
