VACLs on Cisco Catalyst Blade Switch 3020 for HP
Jun 20th, 2007
I'm trying to implement VACLs on our 3020 switches, but it seems like the command is not supported, although it should be supported according to the manual.
Any idea if I'm doing something wrong?
xxxxxx#show version
Cisco IOS Software, CBS30X0 Software (CBS30X0-LANBASEK9-M), Version 12.2(37)SE, RELEASE SOFTWARE (fc2)
xxxxxx(config)#vlan access-map map_1
% Invalid input detected at '^' marker.
Kind regards,
Rene Zeestraten
rzeestraten Tue, 06/26/2007 - 22:37
Hi Henry,
I know it is supported according to the manual, but I'm not able to use it.
Any idea why I can't use it?
