Routing Question .
Answered Question
Jun 20th, 2007
Hi NetPro,
i have some routing question need expert to advice. kindly see the attachment file.
now , i want to see the Tester Pc from Building A.
how do i route it ?
Regars,
Kitten
Correct Answer by amit_kulshrestha_2 about 9 years 11 months ago
Hi Ney,
As per you diagram your core switch of building A and B are directly connected.you can put a static route in core sw of building A like:-
ip route 0.0.0.0 255.255.255.0 172.17.12.6
And put route in core sw of building B like :-
ip route 172.17.12.6 255.255.255.0 192.9.1.12
"YOU CAN USE WILDCARD MASK ALSO"
Kindly revert if it works, also revert if it does not works.Rate it.
Overall Rating: 5 (1 ratings)
royalblues Wed, 06/20/2007 - 23:17
  • Green, 3000 points or more
Which one are the layer 3 devices in your diagram
Narayan
ney25 Wed, 06/20/2007 - 23:44
Hi Narayan,
172.20.1.6 is the my core switch for building A. whereby 172.17.12.6 is core switch for building B.
now i wanna see the tester PC (192.9.1.12) from server (172.20.72.60). possible ?
regards,
kitten
royalblues Thu, 06/21/2007 - 00:06
Ok..
all you can do is to connect the core switches on 2 routed ports and run static routing.
for eg
on sw1
int fa 1/1
no switchport
ip address 10.10.10.1 255.255.255.252
ip route 192.9.1.0 255.255.255.0 10.10.10.2
on SW2
int fa 1/1
no switchport
ip address 10.10.10.2 255.255.255.252
ip route 172.20.72.60 255.255.255.0 10.10.10.1
HTH, rate if it does
Narayan
ney25 Thu, 06/21/2007 - 00:26
Hi Narayan,
you meant both core-switches have to do static route ?
thanks .
kitten
royalblues Thu, 06/21/2007 - 00:37
Yes,
Both switches need to know the routes for the other subnets
Narayan
Correct Answer
amit_kulshrestha_2 Tue, 07/10/2007 - 00:22
Hi Ney,
