Async Line Configuration
Jun 21st, 2007
i am working with 1841 with WIC-2A/s . created Async lines. when i try to telnet to Async lines its connecting. i am able to communicate for very short period after some time communication is going down if i type alphabets of 26 i am able to get only 10 out of it here i am attaching the configuration. plz tell me how to resolve this error.
Hyper terminal side : 9600/8/1/non/Hardware flow control
remote telnet : 192.168.1.202 2018
guruprasadr Thu, 06/21/2007 - 01:51
  • Gold, 750 points or more
HI,
Hope this Link will help you to Solve.
http://www.cisco.com/en/US/customer/products/sw/iosswrel/ps1831/products_command_reference_chapter09186a0080087e18.html#1018303
INFO: Cisco IOS support multi-protocol packet assembler/disassembler (PAD)
services to allow asynchronous terminals to connect to hosts via the X.25 protocol.
PAD services are enabled by default on cisco routers. Disable the service unless
absolutely needed.
PLS Rate if HELPS
Best Regards,
Guru Prasad R
rsjavahar Thu, 06/21/2007 - 03:23
no this is not the solutions. what i am looking
thank you for your advise
Javahar
