is possible to integrate LMS 2.6 with HPOV NNM??
Answered Question
Jun 21st, 2007
is possible to integrate LMS 2.6 with HPOV NNM?? I will install the Integration utility (Common services). But I didnt find the integration package on HPOV pages. There is only Network Node Manager 6.4x, 7.0x, & 7.5 & CiscoWorks LMS 2.2 integration package.
Thank you
Roman
Correct Answer by David Stanford about 9 years 10 months ago
Yes, you can integrated LMS 2.6 with NNM. The integration utility is found at:
http://www.cisco.com/kobayashi/sw-center/cw2000/cmc3rd.shtml
It also comes with on the Common Services CD and is an option when you install CS 3.X
Overall Rating: 5 (1 ratings)
