router ACL
Jun 21st, 2007
its my private LAN archetecture connected to two different offices A and B.
LAN A ( 192.168.10.x )
LAN B ( 192.168.20.x ) & 192.168.60.X
I have a case that , I want from B to communicate only and 10.8, not rest of the hosts.
and in same way I want my A side LAN only communicate to Lan B's 192.168.20.X but not others,
How could it be done ? I am a bit confused over , Please guide. Thanks.
Overall Rating: 5 (1 ratings)
guruprasadr Thu, 06/21/2007 - 02:51
I hope in & 10.8 some Common Service will be Running (like http, ftp, etc.,)
You can write ACL based on Port based.
Pls Rate if Helps
Best Regards,
Guru Prasad R
smothuku Thu, 06/21/2007 - 02:54
Hi ,
create extended access-list on B ..
access-list 101 permit ip host
create extended access-list on A.
apply these on serial interfaces of the routers....
