Jagdeep Gambhir Thu, 06/21/2007 - 06:46
  • Red, 2250 points or more
Hi Carl,
Differences between OM1 & OM2
The OM2 production distribution includes fibers which are optimized over a broad wavelength range. The 500/500 or 400/400 specification can be met by fibers optimized
above 1300nm or below 850nm or at intermediate
wavelengths. The 500/500 spec can be met with fiber optimized for wavelengths well below 850nm.
In contrast, the OM1 production distribution does not include fibers optimized at 850nm; in order to meet the 1300nm 500MHz.km specification the fiber has to be optimized closer to 1300nm. This is also reflected in the product specification (i.e. 160/500)
OM1, OM2, OM3
Naming conventions for Multimode fibre optic transmission where distance limitations are 33, 82 and 300 meters respectively for a transmission speed of 10 Gbps. Frequency ? 200 / 500 Mhz / km, 500 / 500 Mhz / km and 1 500 / 5 Mhz / km respectively.
Hope that helps !
Jagdeep
Note : If that helps then mark it resolved so other can be benefit.
