06-21-2007 04:13 AM - edited 03-14-2019 10:12 PM
I am trying to spec up two unity connection options version 1.2
1 = 1500 users
2 = 3000 users
so far I can only find part code for hardware does any one have the part codes I need to spec this up?
also does version 2 support cm 4.1?
06-21-2007 06:34 AM
Your best option would be to go with a bundle:
UNITYCN-BUNDLE
As far as CUC 2.0 it is not supported with CM 4.1:
http://cisco.com/en/US/docs/voice_ip_comm/connection/compatibility/matrix/cucsccpmtx.html
supported CM versions:
6.0(1), 5.1(1), 5.0(4), 5.0(3), 5.0(2), 5.0(1), 4.3(1)
HTH,
Chris
Log in to Community
