My Cisco 2801 doesnt boot
Answered Question
Jun 21st, 2007
I have a cisco 2801 router which has 64 mb compact flash, it always boots in rommon mode , boot flash: , dir flash:, boot bootflash:, dir flash: , none of these commands works, everytime it issues "Cannot open flash" , or cannot open bootflash, i took out the compact flash and tried to boot using "boot bootflash:" in rommon mode doesnt work, The greatest problem is dont have any IOS backup !!!!!!!!!!Help
Correct Answer by Wilson Samuel about 9 years 9 months ago
I'm afraid, but looks like a hardware issue (with Flash).
Would you please go through this URL and check if its one of the known issues that you are facing?
http://www.cisco.com/en/US/products/hw/routers/ps282/products_field_notice09186a00804a7abf.shtml
Hope that helps,
Please rate if helps,
Kind Regards,
Wilson SAmuel
Overall Rating: 5 (1 ratings)
Wilson Samuel Thu, 06/21/2007 - 05:07
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, July 2015
No worries, as long as the Router has no Hardware issues, it can be always brought up.
Would please give a bit more details by issuing the dir flash: command at the Rommon mode.
We shall be more than happy to help you out.
Moreover you may visit the following link for details
http://www.cisco.com/en/US/products/ps5854/prod_configuration_guide09186a00802c35e9.html
Hope that helps,
Please rate if it helps,
Kind Regards,
Wilson sAmuel
openboy_basanta Thu, 06/21/2007 - 05:35
Thanks Wilson,
It keeps on saying " cannot open flash: " when i try "dir flash: " or "cannot open bootflash:" when i try " dir bootflash:"
Basanta
Correct Answer
Wilson Samuel Thu, 06/21/2007 - 05:46
Hope that helps,
Kind Regards,
Wilson SAmuel
openboy_basanta Thu, 06/21/2007 - 05:48
Thanks Wilson,
Basanta
Thanks Wilson,
Basanta
openboy_basanta Thu, 06/21/2007 - 06:00
Thanks Wilson,
this document really helped looks like the problem the document is talking about
Basanta
