CFA not working at all
Jun 21st, 2007
We are running a Call manager 4.01
CFA was working fine. its not working at all now, even between local phones.
I already checked all CSS and partitions but i don't know where to look anymore.
Can anyone point me to the right direction
When assigned CFA on a phone using CFwdall button, i get a "right arrow" on the top right and the forwarding number is correctly configured on the CCM.
The strange thing is that i can't disable the "Right arrorw" until i do a cFwdall again using the phone own extension.
When dialing from other phone to the one forwarding, this last one rings instead and the caller is redirected to voice mail just after.
Another strange this is even if i disable on CCM all forwarding to voice mail and take the extension voice mail number out, the calling phone is still redirected to the mail box of the called one.
Thanks to all for helping
Pedro
Hi Pedro,
Have you checked the status of the publisher?
In CCM4.x updating CFA is controlled via the publisher. When a user changes the CFA the publishers database is updated and then replicated to the subscribers in the cluster.
If only the publisher is down, the CFA can not be changed, as the subscribers have read-only copies of the database.
I would check the ccm services, event logs first up.
Cheers,
Mike.
acergygroup Thu, 06/21/2007 - 05:56
The publisher seems to be working fine. i checked services and the event viewer and the only thing that caught my attention was
this message
Error: MtpNoMoreResourcesAvailable - No more MTP resources available.
App ID: Cisco CallManager
Cluster ID: StandAloneCluster
Node ID: 172.XX.XX.10
Explanation: MTP resource is not available.
Recommended Action: Install additional MTP or transcoder resources..
d.haeni Fri, 09/07/2007 - 12:23
I had a similar issue today with a 4.2(1)sr1a Installation that was running well for months.
A handful of lines could not be CFAed anymore. If you forced it through the GUI, outside callers received fast busy (unallocated number).
DB Layer was fine (DBLHelper showed OK, DBL Service and eventually Server restarts did not help either). The solution was to fully remove the lines in question from the system (not just from the phone). After re-adding them to the phones, everything was fine.
Rob Huffman Thu, 06/21/2007 - 06:29
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Pedro,
Just to add a note to Mikes good info,here are some good troubleshooting docs for Call Forward All;
Cisco CallManager Issues with Call Forward All
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801b3f4b.shtml#t3
Field Notice: Call Forwarding Failure After a Cisco CallManager 4.x Unexpected Shutdown
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_field_notice09186a0080440e6d.shtml
I was working with someone not long ago that solved this issue by Stopping/Starting the Database Layer Monitor Service
Hope this helps!
Rob
