EoMPLS VC Path
Answered Question
Jun 21st, 2007
Is there any way that I can force the path for a EoMPLC VC other that playing with the IGP ? Also since the mpls core is redundant I want the have a VC via one path and if that path fails the VC should stay down ... is this possible ?
Cristian
Correct Answer by swaroop.potdar about 9 years 10 months ago
I believe Harold missed the /products/ folder in the link as a typo.
Anyways here is the link again which he wants you to use.
http://www.cisco.com/en/US/products/ps6922/products_feature_guide09186a008067cf79.html.
Overall Rating: 5 (3 ratings)
Harold Ritter Thu, 06/21/2007 - 06:54
  • Cisco Employee,
You can actually achieve this by using MPLS TE and the tunnel selection feature.
You would first configure a tunnel, configure the pseudowire to use this specific tunnel and not to take any other path if the tunnel goes downand then configure this specific pseudowire-class on the xconnect statement.
Please refer to te following URL for more information the tunnel selection feature.
http://www.cisco.com/en/US/partner/ps6922/products_feature_guide09186a008067cf79.html
Hope this helps,
Harold Ritter Thu, 06/21/2007 - 08:46
  • Cisco Employee,
Sorry about that. Thanks Swaroop for posting the proper URL.
cristiangal Thu, 06/21/2007 - 13:06
I think I've understand it. Just create the tunnel from PE to PE via a predefined path and a pseudowire-class using that tunnel and just apply the pw-class to xconnect. I wouldn't use TE since I'm not very familiar to it but I guess I will have to start look into it more closely.
Thanks for the help,
Cristian
