How many PRI's can a 3725 handel
I have a 3725 router with 1 pri dedicated to voice. I am in the process of getting 2 more pri's for a total of 3 pri's. My question is can my route support them. I know that the router suppots 2 AIM slots which will be used by 2 AIM-VOICE-30's but if I have 3 PRI's that is a total of 69 channels and I only have enough DSP's for 60 Channels. So do I need a new router or will this configuration work.
Thank you
paolo bevilacqua Thu, 06/21/2007 - 07:27
  • Hall of Fame,
    Founding Member
yes you are correct, 69 channels won't fit in the 3725 via AIM-VOICE-30. But, if you want to hang on to this router for a little longer, and you have a free NM slot, you could try an NM-HD-xxx (too many variants to list here) that wold support the the additional T1s without need for the AIM, as it has DSP on-board. See what modules are supported on your router:
http://cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a00800e73f6.shtml
rseiler Fri, 06/22/2007 - 21:13
  • Silver, 250 points or more
Don't use the AIM-VOICE-30 module, use the NM-HDV2-* modules which have the same PVDM2 DSP modules as the ISRs.
I have several c3725 routers running with 2 each of the NM-HDV2-2T/E1 modules (total of 4 T1 ISDN PRI trunks) with 50-60% CPU under full call volume.
I had a bunch of issues with the AIM-VOICE-30 modules as they are a single (older) 5510 DSP and have significant software limitations.
