PIX 505 to 515E swap
Jun 21st, 2007
Hi there,
I am in the process of swapping out a PIX 505 running 5.0(2) to a 515E running 7.2(2). After attempting to convert the older configuration I have not been able to get the new model to work correctly. Even without any ACL applied I cannot get traffic to pass through the PIX. The interface configuration and routing is the same as that on the older model. Any suggestions are greatly appreciated!
ESCPIX# show config
: Saved
: Written by enable_15 at 06:37:41.748 UTC Thu Jun 21 2007
PIX Version 7.2(2)
hostname ESCPIX
domain-name fuhsd.org
enable password xxx
names
interface Ethernet0
speed 100
duplex full
nameif outside
security-level 0
ip address 205.x.x.2 255.255.255.0
interface Ethernet1
speed 100
duplex full
nameif inside
security-level 100
ip address 192.168.200.2 255.255.255.0
passwd xxx
ftp mode passive
dns server-group DefaultDNS
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image flash:/asdm-522.bin
asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 10.190.155.0 255.255.255.0
nat (inside) 0 204.88.146.0 255.255.255.0
nat (inside) 0 204.88.158.0 255.255.255.0
nat (inside) 0 205.173.40.0 255.255.255.0
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.x.x.173.47.1 1
route inside 204.88.158.x.x.255.0 192.168.200.1 1
route inside 10.190.155.0 255.255.255.240 192.168.200.1 1
route inside 172.31.0.0 255.255.0.0 192.168.200.1 1
route inside 172.30.0.0 255.255.0.0 192.168.200.1 1
route inside 172.29.0.0 255.255.0.0 192.168.200.1 1
route inside 172.28.0.0 255.255.0.0 192.168.200.1 1
route inside 172.27.0.0 255.255.0.0 192.168.200.1 1
route inside 172.26.0.0 255.255.0.0 192.168.200.1 1
route inside 10.10.30.0 255.255.255.0 192.168.200.1 1
route inside 205.173.41.0 255.255.255.0 192.168.200.1 1
route inside 205.173.42.0 255.255.255.0 192.168.200.1 1
route inside 205.173.43.0 255.255.255.0 192.168.200.1 1
route inside 205.173.44.0 255.255.255.0 192.168.200.1 1
route inside 205.173.45.0 255.255.255.0 192.168.200.1 1
route inside 172.16.0.0 255.255.0.0 192.168.200.1 1
route inside 172.17.0.0 255.255.0.0 192.168.200.1 1
route inside 172.18.0.0 255.255.0.0 192.168.200.1 1
route inside 172.19.0.0 255.255.0.0 192.168.200.1 1
route inside 172.20.0.0 255.255.0.0 192.168.200.1 1
route inside 172.21.0.0 255.255.0.0 192.168.200.1 1
route inside 192.168.40.0 255.255.255.0 192.168.200.1 1
route inside 192.168.16.0 255.255.255.0 192.168.200.1 1
route inside 204.88.146.224 255.255.255.240 192.168.200.1 1
route inside 172.22.0.0 255.255.0.0 192.168.200.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet 205.x.x.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
JORGE RODRIGUEZ Thu, 06/21/2007 - 09:59
  • Green, 3000 points or more
basic question !! when you do " show interfaces " what is their up/down status.
also, from within the pix can you ping all of your interfaces or not.
sharring Thu, 06/21/2007 - 10:12
Thanks for replying.
When I make the swap the interfaces show as up, but show traffic has zeroes across the board. Also, the ping I am running to the internal interface ip address fails after I make the swap. However I have confirmed the physical interface is okay by changing the ip address and connecting to our network. I have the PIX disconnected now and when I try to ping either interface from within the PIX via console I get a "No route to host" message. Not sure if that is normal or not.
