06-21-2007 07:27 AM - edited 03-10-2019 03:14 PM
I am setting up 2 ACS appliances (HW 1113, SW 4.1). After the initial configuration (IP address, admin pass etc) and reboot, the devices don't seem to start up or bring the login prompt (even after a whole night booting).
What might be the problem either with the appliance or my patience?
Solved! Go to Solution.
06-21-2007 07:32 AM
If you are only getting something like starting windows from console,
Then make sure that you are using Appliance name less than 15 characters without spaces.
Prem
06-21-2007 07:32 AM
Prem
06-21-2007 09:09 PM
Hi pbanga,
The Appliance name is 17 characters. I will reimage and rename to 14 characters. Thanks for the tip.
07-20-2007 07:19 AM
ACS Engine runs on Windows 2000. Windows NETBios names cannot be longer than 15 characters and hence the issue I had.
