mohammedmahmoud Thu, 06/21/2007 - 07:54
  • Green, 3000 points or more
Frame = Layer 2 header + packet + layer 2 trailer. When talking about layer 2 devices we always refer to frames.
Packet = IP header + datagram. When talking about layer 3 devices we always refer to packets.
They are sometimes used interchangeably but technically they are different.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
carl_townshend Mon, 06/25/2007 - 01:20
So if the frame stays on layer 2 its still a frame, and when it crosses a router it adds ip header info so its then called a packet ??
mohammedmahmoud Mon, 06/25/2007 - 01:35
We can think of it as the Frame contains the packet inside it as its payload, as long as the frame is layer 2 switched only the frame header is checked, but if the frame paths over a router, the router will need to decapsulate the frame in order to be able to check the packet header.
NOTE: The frame is constructed in the first place after the packet is fully structured with its ip header.
HTH,
Mohammed Mahmoud.
pciaccio Thu, 06/21/2007 - 09:30
  • Silver, 250 points or more
It is:
S = Segment = Layer 4
P = Packet = Layer 3
F = Frame = Layer 2
Hope this helps...Please rate...
srue Thu, 06/21/2007 - 10:25
  • Blue, 1500 points or more
B = Bit = Layer 1 (1's and 0's)
(just for completeness)
