FXO off-hook forever; IP Phone keeps ringing.
Hi, I am using CCM4.2 and 2811 as GW, I configured the FXO ports and assigned DN's respectively. When I tried to call from outside, it is forwarded to the assigned DN and rings, but the IP phone keeps on ringing even if i hanged-up, I checked the voice port status and it is stuck on off-hook. Each voice port has the following commands:
Please help!
thomuff Thu, 06/21/2007 - 08:52
Did you try shut /no shut the voice port? or
resetting the phone?
TomGarman Fri, 06/22/2007 - 06:16
Does this happen to all of your lines coming into the FXO card, or just one? I recently (last week) had a batch of FXO cards that were bad (5 cards total). The ports on the card would work fine for a day or so, and then fail (causing incoming calls to ring forever). If you check the output of 'debug vpm signal' it may help to narrow the cause.
senolgokhan Fri, 06/22/2007 - 06:33
u have solved your problem?if so how ?
because i have similiar problem
i got ccm 4.1.3 and fxo ports connected fct's for gsm connections
Gateway and CCM has mgcp connection.
on callmanager fxo port configuration I configured Attendant DN for incoming calls .
what is the relation of using battery reversal command for directing the incoming calls to Attendant DN which is specifed on callmanager.
Because if i use battery reversal under fxo port , calls routed to Attendant DN but only one time phone rings and then disconnects.
But if i use no battery-reversal command under fxo ports calls go to the AttendantDN and call can be set up succeessfully.
any idea
sheerazkhatri Fri, 06/22/2007 - 22:25
Try those 3 commands
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
