Unfortunately, this no longer deals with the CM or the Unity. The only thing you can do is to have the people contact their Telco and get the Caller-ID block feature.
The only issue with this is that some business or residential numbers do not allow calls from Caller-ID block numbers, but some give the option for the caller to punch in a sequence of numbers to unblock the number.
Hope this helps.
