wrr-queue command
Jun 21st, 2007
I am configuring some 3750 switches for a mitel ip phone solution. The Mitel documentation says to use the wrr-queue command at the interface config mode, but it is not available.
Overall Rating: 5 (1 ratings)
royalblues Thu, 06/21/2007 - 11:26
  • Green, 3000 points or more
Friend,
The 3750 supports SRR(shaped round robin) instead of WRR(weighted round robin)
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12225see/scg/swqos.htm#wp1284809
A typical configuration example would be
interface
mls qos trust dscp
queue-set 1
srr-queue bandwidth share 1 39 24 37
srr-queue bandwidth shape 5 0 0 0
priority-queue out
global config
mls qos map cos-dscp 0 8 18 26 34 46 48 56
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 1 4
mls qos srr-queue output cos-map queue 3 threshold 3 2
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 1 1
mls qos srr-queue output dscp-map queue 1 threshold 3 46 40
mls qos srr-queue output dscp-map queue 2 threshold 3 48 56
mls qos srr-queue output dscp-map queue 2 threshold 2 24 26 28 30
mls qos srr-queue output dscp-map queue 2 threshold 1 32 34 36 38
mls qos srr-queue output dscp-map queue 3 threshold 3 16 18 20 22
mls qos srr-queue output dscp-map queue 4 threshold 3 0
mls qos srr-queue output dscp-map queue 4 threshold 1 8 10
mls qos queue-set output 1 threshold 2 75 85 50 400
mls qos queue-set output 1 threshold 4 15 100 50 400
HTH, rate if it does
Narayan
