scottmac Thu, 06/21/2007 - 11:51
  • Green, 3000 points or more
Do a Google search for "Captive Portal" - there are a variety of systems, some free, some are big bucks.
"nocat" is a fairly popular free (runs on Linux, I think, or BSD).
Cisco sells BBSM; captive portal is one of several things it'll do.
Good Luck
Scott
ericgarnel Thu, 06/21/2007 - 12:21
  • Gold, 750 points or more
nocat is a bit dated. try monowall, pfsense or chilispot.
The bbsm as of 5.3 did not natively support the Cisco lightweight AP solution (lwapp) natively. It could be done, but to the results desired or utilization of bbsm features.
ericgarnel Fri, 06/22/2007 - 05:33
Yes, but there is no way to do an unencrypted page, thus have an annoying cert error popup & delay or purchase a valid cert or create a cert & install root cert on clients browsers.
Also, the controller has only 30k of space, not much room for text or graphics.
I like the pfsense & monowall solutions because they provide for more flexibility and you can traffic shape there as well.
I push the wireless traffic through a pair of routers running glbp and then out to two pfsense portals running active-active. This provides for load balancing & failover
ericgarnel Mon, 06/25/2007 - 05:57
is this with authenticated users only? or will it work with web pass-thru as well?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
