Cisco Secure Service Client and CTA - Wireless NAC support
I'm deploying NAC framework via wireless with NAC L2 802.1x. The authentication is set to PEAP. It work fine but when I enable the posture validation check the connection fail.
I'm using the following software version:
Access Point: AIR-AP1131AG-A-K9 - 12.3(8) JA2
CSSC (Cisco Secure Service Client): 4.1.2
CTA: 2.1. I use "CtaAdminEx-win-" file
ACS: 4.0
In the client PC (on the task bar) I only see the CSSC icon, I'm not see the CTA icon. If I go to Administrative tools --> Services the "Cisco Systems, Inc. CTA Posture State Daemon" is started.
It seems that posture validation is not performed because communication between CTA and CSSC is not working.
Must I configure anything to establish communication between CTA and CSSC?
