ACS errors.
Jun 21st, 2007
Today I had the following problem with my ACS server:
Event Type: Warning
Event Source: Perflib
Event Category: None
Event ID: 1016
Date: 6/21/2007
Time: 12:10:38 PM
User: N/A
Computer: CiscoACS
Description:
The data buffer created for the "CSTacacs" service in the "C:\WINNT\system32\tac_mon.dll" library is not aligned on an 8-byte boundary. This may cause problems for applications that are trying to read the performance data buffer. Contact the manufacturer of this library or service to have this problem corrected or to get a newer version of this library.
Data:
0000: 14 38 16 00 0c 04 00 00 .8......
which was then follwed by this error:
Event Type: Error
Event ID: 1008
Date: 6/21/2007
Time: 12:14:38 PM
User: N/A
Computer: CiscoACS
Description:
The Open Procedure for service "CSTacacs" in DLL "C:\WINNT\system32\tac_mon.dll" failed. Performance data for this service will not be available. Status code returned is data DWORD 0.
Data:
0000: 02 00 00 00 ....
This eventually led to the ACS services crashing and attempting to restart. I had to reboot the box in order to restore the services.
Any ideas as to the cause of this problem? The server has been up and stable for 4 years and is just now starting to give problems.
BTW - running ACS 3.3 on Windows 2000 Server w/ SP4.
Overall Rating: 2 (1 ratings)
Jagdeep Gambhir Thu, 06/21/2007 - 16:33
  • Red, 2250 points or more
HI ,
These errors are not everytime related to ACS problem. If would suggest you to upgrade acs if its ver is less then 3.3.3.
Please rate if helps.
Jagdeep
Premdeep Banga Fri, 06/22/2007 - 03:53
  • Gold, 750 points or more
The error messages that you have reported, is associated to a bug, but is marked as cosmetic,
CSCdu43103 : ACS Perflib cosmetic error message 8-byte boundary alignment
I would suggest you to do following,
Please remove all the file from following location and then try ( these files are debug files, so we donot require them) :
\CSAuth\Logs
\CSRadius\Logs
\CSTacacs\Logs
\CSLog\Logs
\CSMon\Logs
\CSAdmin\Logs
\CSDbsync\Logs
- Also, if you have ran CSSupport.exe that is under, \Utils
Re-run it and if TACACS or RADIUS packet dump was on, turn it off.
- In the end I would suggest you to go to ACS version 3.3.4.12 with Patch 2
Prem
Trending Topics - Security & Network
