ACS on virtual server
mdcole
Are there are issues or concerns with installing ACS on a virtual server?
The server will authenticate approximately 500 devices and around 4000 users.
Premdeep Banga
Level 7
Level 7
Good news for you!
ACS is supported on VMWare, but you need to be on version 4.1.x or above.
System Requirements:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/acs41/rnotes/rnacs41.htm#wp140886
System requirements are documented in the Installation Guide for Cisco Secure ACS 4.1 Windows. The following updates have been made to the ACS system requirements. ACS 4.1 supports:
?Pentium dual-core processors. This support is with Intel but not Advanced Micro Devices (AMD).
?VMware. ACS 4.1 was tested on the following VMWare platform:
?VMWare ESX server 3.0.0
?Processor?AMD Opteron Dual core
?# of Virtual machines?4
?Guest operating system?Windows 2003 Standard Edition
?RAM for each guest operation system?3 GB
Prem
Jagdeep Gambhir
Level 10
Level 10
Hi ,
ACS is not supported on Virtual Servers. As far as number of users are devices are concerned, that is not a issue.
Jagdeep
Premdeep Banga
Level 7
Level 7
Good news for you!
Prem
