Application Control Engine (ACE) Deployment
Jun 21st, 2007
I am looking at deploying an ACE to load balance some Terminal Servers and some Citrix Servers for a large serverfarm consisting of approximately 6 - 10 realservers. We are currently using DNS round-robin to load balance these services but it is not working properly because of the fact that we cannot detect realserver failure - hence the use of the ACE health monitoring.
I face the following potential problems:
1. There is a possibility that we cannot change the IP's on the existing servers that are to be loadbalanced. This imposes a problem for a routed implementation.
2. Assigning a new VIP for the serverfarm might not be possible as it requires reconfiguration of all client machines, which is a large population.
Any comments/ideas? I have thought of using a bridged mode implementation (trickier than L3 Routed implementation). Can I still achieve load balancing without using a VIP when using bridged mode?
Any thoughts on achieving this in bridged mode?
Thanks in advance for any ideas/pointers.
Gilles Dufour Fri, 06/22/2007 - 04:24
  • Cisco Employee,
what ip address are the clients using to connect right now ?
I don't see how you could perform loadbalancing without a virtual ip address.
Bridge mode is definitely the solution to use if you can't readdress the servers.
It's not really more complex than the routing mode.
Gilles.
lionellemaire Wed, 06/27/2007 - 04:33
You could define many VIPS corresponding to the real servers IP and point them all to a single serverfarm which then load balances among the servers.
Would that work ??
