PRI Faxing issues over Wireless network
Jun 21st, 2007
Is there a way that I can properly troubleshoot if I have a LEC issue or dropped packets from a 2421 or ATA?
I have issues terminating many faxes from 2421's. I almost never get ATA to send fax properly. This is,I think that config is right as sometimes they go through, sometimes they don't. For the longest time I thought it was dropped packets across the WLAN, but know I see that even on great links with no bandwidth being consumed, their are certain numbers that always fail! Thought it may be the PRIs interaction with the gateway/ccm or remote 2421....
paolo bevilacqua Thu, 06/21/2007 - 13:38
  • Hall of Fame,
    Founding Member
is the T1 controller clean of slips on the gw?
Have you configured the ATA for fax accordingly to the many docs on the matter ?
