Unity Voice Mail Broadcast Function?
Jun 21st, 2007
Greetings,
I've been told there is a way to send out pre-recorded messages to voice mail. I'm going to go out on a limb and assume this is through unity. What function is this called can anyone point me to a cisco howto guide?
Rob Huffman Fri, 06/22/2007 - 05:23
Hi Marcus,
Have a look at this good feature;
Unity Broadcast Message Manager
Sending a New Broadcast Message
To send a new broadcast message, press the Add new message button on the main form and the Send New Broadcast Message form will display.
This form lets you select a WAV file off the local hard drive or a networked drive available on the local system, select your date ranges or indicate you would like no date restrictions for the message and select the subscriber to be the sender or owner of the broadcast message and press the insert button. Both the WAV file and subscriber are required properties for the message insertion to work properly.
From this link;
http://ciscounitytools.com/HelpFiles/BroadcastMessageManager/BroadcastMessageManager.HTM#_Toc117672270
http://ciscounitytools.com/App_BroadcastMessageManager.htm
Hope this helps!
Rob
marcuscastellanos Mon, 06/25/2007 - 15:09
Looks nice.. the only problem with this is it requires Unity 4.0(5)we currently are set at 4.0(4)
