1760 router with VIC2-2EM
Jun 21st, 2007
I am having a problem passing audio from one 1760 to another. There is no keying or hooking involved. I need a dedicated always open 4 wire path. Any Suggestions would be helpful.
paolo bevilacqua Thu, 06/21/2007 - 15:06
  • Hall of Fame,
    Founding Member
are you familiar with the command "connection trunk" ? That will make the path be always open.
coreylarew Thu, 06/21/2007 - 15:17
yes i am. How can I be sure that I am directing the port correctly
paolo bevilacqua Fri, 06/22/2007 - 00:30
  • Hall of Fame,
    Founding Member
The once you configure the correct port under dial-peer, it will be OK.
