JORGE RODRIGUEZ Thu, 06/21/2007 - 15:34
  • Green, 3000 points or more
can you provide " show sys " and " show environment power ", it could be the card is not getting enough power from the switch power supplies.
JORGE RODRIGUEZ Thu, 06/21/2007 - 18:59
you only have one power supply, I suspect the WS-CAC-2500W PS is not enough to power the additional blade you're installing, I could be wrong. For the sake of test, if blade 7 is not used, I would slightly pull blade from slot 7, and re-insert the 6148A in slot 6 to see if it comes online.
gmvburg23 Fri, 06/22/2007 - 02:53
I pulled all blades out excluding the SFM2 and the X6516 but it was still unreadable. I had a 6548 and 6148a in the chassis simultaneously and they both ran fine. Also, I have only one PS in another 6500 chassis that houses several blades including two x6516 with no problem.
JORGE RODRIGUEZ Fri, 06/22/2007 - 03:19
did you try instlling the 6148a in the other 6500 chassis? if the blade don't come up in the other 6500 then you may have a faulty card.
gmvburg23 Fri, 06/22/2007 - 03:52
it works fine even in the 6509 chassis when I boot up from the linear flash card that has the code for the 6513 chassis.
gmvburg23 Fri, 06/22/2007 - 05:52
Is the WS-X6816-GBIC even supported under CatOS?
