NAM snmp to Cisco6509 Sup720
Answered Question
Jun 21st, 2007
Hi, iam having a communication problem between the NAM and the switch, with the following message in the NAM web page:
Performing SNMP test from NAM ( to switch (
Access to the switch failed. This may be due to the switch's SNMP access control list is enabled.
Check if your switch's SNMP access control list is enabled and make sure
that the NAM's IP address is included in the access control list.
I have found the following message on my trapd station:
2007-06-21 19:49:05 [x.y.132.25] (via [x.y.81.24]) TRAP, SNMP v1, community public
enterprises.9.1.283 Authentication Failure Trap (0) Uptime: 0
enterprises. = IpAddress: x.y.130.254
It seems to be a commnuty string problem, but the snmp communities are the same in the NAM and in the switch.
Besides... the log message claims for "public" community string.
The IP .254 is the NAM
The IP .25 is the Sup720
The IP .24 is my CiscoWorks
I can ping from the Sup720 to the NAM and from the NAM to the Sup720.
The access-lists for SNMP has the IP of the NAM.
I have the following command in the switch:
analysis module 8 management-port access-vlan 330
Following the VLAN configuration:
interface Vlan330
description ama/SC-SAb/x.y.130.192/26/V330
mac-address 4209.0882.0e00
ip address x.y.130.196
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no ip mroute-cache
logging event link-status
load-interval 60
arp timeout 420
standby 1 ip x.y.130.193
standby 1 timers 1 6
standby 1 priority 200
standby 1 preempt
standby 1 authentication vlan330
standby 2 ip x.y.130.194
standby 2 timers 1 6
standby 2 priority 150
standby 2 preempt delay minimum 60
standby 2 authentication vlan330
Also this command in the NAM:
supervisor address x.y.132.25
I do not know what else i should check...
Correct Answer by Joe Clarke about 9 years 4 months ago
Note: when you remove the supervisor address, you need to leave the loopback IP in your ACL.
Overall Rating: 5 (2 ratings)
Joe Clarke Thu, 06/21/2007 - 15:37
The "public" in the trap is the community string being used to send the trap, and not the one that used to do the polling. What version of software is running on the NAM, and what version of IOS is on the switch? What model of NAM is this?
It would also be helpful to see the output of "show vlan", a full "show run" from the switch, and a "show snmp" from the NAM. This would help to confirm if there are SNMP ACLs, typos, or a problem with the VLAN. If you cannot share this information, I suggest you open a TAC service request to get further assistance.
agiacometti Fri, 06/22/2007 - 06:29
Ive perform a showtech in the NAM, and if found this...
Switch IP Address
Switch Community String
Joe Clarke Fri, 06/22/2007 - 09:21
It looks like your access list 83 is the problem. The NAM polls the switch via the internal loopback address of 127.0.0.X where X is a factor the NAM's module number. Since the NAM is in slot 8, add to your SNMP Community string access list, and see if that helps.
agiacometti Fri, 06/22/2007 - 09:47
I try that... but still the same...
I am thinking in the results of the showtech, that i mention previously
Switch IP Address
[email protected]
and this community string changes every time i reset the module.
As extra info, the ACL has no hits, so i think that maybe the community string used by the NAM to query the Sup720 is wrong... or blocked... some bug?
Joe Clarke Fri, 06/22/2007 - 10:02
Try removing the supervisor address on the NAM with the command "no supervisor address" then reload the NAM, and see if that helps.
Correct Answer
Joe Clarke Fri, 06/22/2007 - 10:03
Joe Clarke Fri, 06/22/2007 - 10:45
You are being affected by the known bug CSCsi45556. The only workaround is to re-enable the internal NAM/switch communication channel (which is what you just did).
