connect 3750 with 3500XL etherchannel
elkono200
what i have to configure if i would like to connect a 3750 with a 3500.
etherchannel load-balancing ???
port-channel 4 ???
someone has a suggestion?
thx
3 Accepted Solutions
mahmoodmkl
Level 7
Level 7
If u r looking for configuration of etherchannel fllow the below link.
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a0080094647.shtml
Mahmood
cisconoobie
Level 2
Level 2
you need to setup a trunk.
On both Ports connecting the 3750 and 3500.
#switchport mode trunk
switchport nonegotiate
if you want to setup etherchannel, meaning aggregate 2 or more ports into 1 logical add this to all ports on the above config.
#channel-group 1 mode on
Do this to make sure you have a trunk properly setup on the etherchannel.
#show etherchannel summary
You don't have to set up a trunk if you are just running 1 vlan down the pipe , just use the etherchannel commands if this is the case .
The 3500 side will look like this
interface FastEthernet0/1
port group 1
!--- The port group command
!--- makes this interface a member of channel group 1.
interface FastEthernet0/2
port group 1
!--- This interface is also a member of channel group 1.
mahmoodmkl
Level 7
Level 7
Mahmood
cisconoobie
Level 2
Level 2
port group 1
port group 1
