WLSE error with new firmware 12.4-3g
joseavalero
when i update my 1131 APs, WLSE send this message ;
Inconsistent device state found:
CISCO-DOT11-IF-MIB cd11IfStationConfigTable.cd11IfStationRole must be in the range [1..11] (was 0)"
Please mark this thread as resolved so that others can benefit for it.
Prem
Premdeep Banga
Level 7
Level 7
Check this out,
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsi58022
CSCsi58022 : IOD : Inconsistent Error messages in WLSE for 1130 and 1240
Alternate Headline: IOD : Inconsistent Error messages in WLSE for 1130 and 1240
Symptom:
WLSE reports a fault as follows.
Inconsistent device state found: Device "APXXXX": ifIndex=1, MAC=XX-XX-XX-XX-XX-XX: "CISCO-DOT11-IF-MIB cd11IfStationConfigTable.cd11IfStationRole must be in the range [1..11] (was 0)"
Condition:
Reproducibility : unknown
Frequency : unknown
Components:
WLSE Ver2.15
Aironet Ver12.4(3g)JA
Workaround:
This phenomenon doesn't impact function.
Prem
OK , thanks
Prem
i've the same problem of this discussion, the system is composed of:
WLSE 1030 Release 2.15
AP 1240 with IOS 12.4(10b)JA3 and 12.4(10b)JA
In partcoular, all APs have the radio interface 802.11a turned off, but i always see this fault:
Inconsistent device state found: Device "AP254.xxxxx.xxx": ifIndex=2, MAC=00-1c-57-84-af-20: "CISCO-DOT11-IF-MIB cd11IfStationConfigTable.cd11IfStationRole must be in the range [1..11] (was 0)"
i would like to know if there is a way to hide this fault permanently.
Is possible that this is a bug (CSCsi58022)?what is the solution?
thanks a lot.
