Difference between 3550 and 3560??
Jun 21st, 2007
I don't know if this exist but I'm looking for a matrix that shows the feature and hardware/software differences of all Cisco access switches. For example 3560 vs 3560 vs 3750 etc. Something simple that just shows the major differences between the models.
Overall Rating: 4.3 (4 ratings)
mohammedmahmoud Fri, 06/22/2007 - 00:05
3550 is EOS/EOL, Enterprise customers are encouraged to migrate to Cisco Catalyst 3750 Series and Catalyst 3560 Series switches, which provide new and enhanced functionality including IEEE 802.3af Power over Ethernet (PoE), higher-density Gigabit Ethernet (GE), and IPv6 routing. The Cisco Catalyst 3750 Series switches feature Cisco StackWise? technology, a 32-Gbps stack interconnect that allows customers to build a unified, highly resilient switching system, one switch at a time.
Always use the Cisco Switch Guide:
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
