mpls mtu command on subinterfaces
Jun 22nd, 2007
hi,
i have a 7604 router with som gig interfaces.
i have some subinterfaces (802.1q) interfaces on the physical interface, which are trunks to other mpls pe router, so i have to do labelswitching.
therefore i use the command "mpls mtu 1512".
the problem is, that i only can configure this command on the physical interface and NOT on the subinterface.
or is it so, that if i configure this on the main/physical interface that automaticly this is also so for the subinterfaces??
interface GigabitEthernet4/0/1
description MPLSRBGOPE02: phy.Link to MPLSRBGOSwi02 (Gi4/0/1-Trunk)
no ip address
load-interval 30
shutdown
negotiation auto
mpls mtu 1512
interface GigabitEthernet4/0/1.190
mplsrbgope02-test-76(config)#interface GigabitEthernet4/0/1.190
mplsrbgope02-test-76(config-subif)#mpls mtu ?
<64-1500> MTU (bytes)
mplsrbgope02-test-76(config-subif)#mpls mtu 1512
% Invalid input detected at '^' marker.
rabeder Mon, 06/25/2007 - 01:10
hi,
thanks for answer -
... andi it does mean that it is automaticlly
active on the eth subinterfaces ???
(mpls mtu 1512)
