CNR 6.1 - bind dhcp server on specific interfaces
Jun 22nd, 2007
hello everybody,
I would like to bind my CNR dhcp server ONLY on specific interfaces, instead of all server's interfaces as default installation does.
Can anyone tell me how to do this?
best regards
smalkeric Thu, 06/28/2007 - 05:36
  • Silver, 250 points or more
If you wish to LIMIT the interfaces that CNR DHCP will listen on then you can disable 'discover-interfaces' and manually configure just the interface(s) you desire.
Also, DNS cannot yet be restricted to a subset of the interfaces. it will currently always listen on all it finds..
