Route traffic by selective tcp port ?
Hi All,
Can I route traffic on either a layer 3 device whilst being selective about the destination port ??
I have been asked if I can route all MSN Messenger traffic via another ISP route (rather than blocking it altogether), freeing up valuable bandwidth on our main web link.
I think that the port is 1863 for MSN ? is there a way of doing this ??
Cheers,
Stuart
Overall Rating: 5 (1 ratings)
Edison Ortiz Fri, 06/22/2007 - 05:46
You need to implement Policy Based Routing and apply it at the ingress interface of the L3 device.
Your PBR would look like this:
ip access-list extended MSN
permit tcp any any eq 1863
route-map MSN permit 10
match ip address MSN
set ip next-hop [ISP next hop]
[ingress interface]
interface f0/0
ip policy route-map MSN
Hi EdisonOrtiz,
Many thanks for your reply.
I've tried implementing this onto both a 3750 & 3560 switch but to no avail. I don't seem to be able to input the 'IP POLICY ROUTE-MAP MSN' statement into the desired interface, it just display's unrecognised command. So, I tried implementing it into the VLAN interface which is accepted but then I see no traffic matching the access-list.
I must be doing something silly here ...
Stu
Edison Ortiz Sun, 06/24/2007 - 10:19
You need to change the SDM in the switch to sdm prefer routing and then reboot.
royalblues Mon, 06/25/2007 - 07:48
Which image are you running on the switch,
ipbase or IP services?
Can you post sh ver and sh runn
Narayan
Edison Ortiz Mon, 06/25/2007 - 10:10
The policy-based routing can only be applied on routed interfaces. If you are trying to apply it on a L2 switchport interface, it won't work. You need to apply at the SVI (Switch Virtual Interface) of the respective VLAN.
