switch performance
Jun 22nd, 2007
Hi all, is there anything which would affect the performance of my switch, users are complaining about slowness, the duplex,speed is all set fine. there are alot of recieve discards, any ideas ?
farkascsgy Fri, 06/22/2007 - 06:02
On all ports are appear the high error rate? How is the CPU and Memory usage of the device. Have you checked the cables, if you can change (length, connectors).
Please rate me if I helped.
cisconoobie Fri, 06/22/2007 - 06:09
#show controllers ethernet-controller
See if you have any ports that have a high amount of "too old frames" or "System FCS Error Frames".
lgontarsk Fri, 06/22/2007 - 06:20
can you post the config, show ver and an interface with discards?
